Whirlpool S20DRBB32-A/G
  • #63953
    VillageIdiot2
    Blocked
    Help required!
    Unit runs for a short while, switches off then will not restart unless you power down and back on again. We’ve changed the PCB, Defrost heater and Thermal block but still seems to be the same.
    Any Whirlpool guys out there able to give any help?
    (8586 158 15000)
    Thanks, Ade 🙂
    #355626
    Re: Whirlpool S20DRBB32-A/G
    long shot
    have you tried a different socket
    ie bad socket = arcing = computer board lockups
    boggoff
    Do you loose the supply to the compressor? try running a seperate supply to the compressor only, you may have a compressor problem.15 years working on these never had fault like this
    #355628
    VillageIdiot2
    Blocked
    Hi guys…
    Yeah it seems that when it gets to temperature, it shuts down and will not restart unless you power down. End result is unit warms up, alarm sounds, customer powers down and back on then unit runs again… It’s defo a weird one!
    Ade
    #355629
    Is the heater actually coming on ?
    bryan
