Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Whirlpool S20DRSS10 – circuit board advise needed
- This topic has 5 replies, 3 voices, and was last updated 19 years, 6 months ago by
ronmi.
October 4, 2006 at 12:00 am #21388
ronmi
ParticipantHi, I baot the fridge freezer about 1.5 years ago. Apparently, the circuit board is gone.
When I looked for a new circuit board in the different sites, I found only ‘close’ to it of ‘close’ models.The product code is 858615415010. What circuit do I need? the one that was suggested to me is a bit different than the one I have, and my engineer does not know exactly how to install it correctly.
Ane advise please?
October 4, 2006 at 8:11 am #190677gegsy
ParticipantRe: Whirlpool S20DRSS10 – circuit board advise needed
I would look for an engineer off this site from my link below whom will be able to confirm the fault and be able to fit the spare competently.Greg
October 4, 2006 at 12:48 pm #190678ronmi
Thank you Greg,
The only problem is that I sent the fridge to another country (my family moved from here). Tn engineer there said I need to buy a new card here (not available there). I bought part no. 481221778192. The engineer there tried to install it but it is not exactly the same card (you mentioned 48122178172). Can I still user 481221778192, and if so, how to install it? If not, than I will buy 48122178172…
I know this is a bit auquard, but I have no one to get this information from.
October 4, 2006 at 1:44 pm #190679Martin
ronmi wrote:(you mentioned 48122178172)
How did he do that without moving his lips I wonder? 😉
Spookily enough, he is correct and 48122178172 does appear to be the correct part you require! 🙂
October 4, 2006 at 4:41 pm #190680gegsy
Hi ronmi
You never said what the fault was initially so would be difficult to confirm if the “card” YOU mention is actually at fault 😉Greg
October 18, 2006 at 2:49 pm #190681ronmi
😀 😀 Thank you all for your help. I installed the correct panel (as mentioned by you) and all works perfectly. 😀 😀
I am now stuck with a circuit I do not need(part no. 481221778192) and ready to sell it. Anybody needs one? ❓ ❓ -
