Whirlpool S20DRWW30
  • #49939
    Vladd
    Got a problem with this American fridge/freezer if someone can help.
    The problem started when the display on the freezer went to — and the alarm sounded, the freezer then stopped cooling. After replacing the rear module and freezer ntc, the freezer is cooling intermitantly and the fault re-occurs once the sense light goes out.
    Model 8586 159 15000
    Serial 110435 003411
    Purchased 2005
    I have read about maybe both the front and rear module might need replacing but cannot find a deffinate answer.
    Any help would be greatly appreciated.
    #302799
    Vladd
    Re: Whirlpool S20DRWW30
    Are there any Whirlpool guys out there who can help please ???
    I’ve spent long enough going through the public forum listing and still cannot see an answer.
    #302800
    jackster
    It sounds like its either a faulty pcb or maybe the de-frost heater itself? Also worth checking for dust build up behind the grilll at the bottom.
    #302801
    Payney
    What you have read about changing both boards is probably not going to apply here as the serial no. you have given means it was made after week 30 of 2004 and its only the models before this date that had a software conflict.
    If its freezing and then stops I would personaly check the defrost heater and connections to the defrost heater which somtimes expand.
    Hope this helps.
