WHIRLPOOL S20ER Side by side F/F
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries WHIRLPOOL S20ER Side by side F/F
  • #20566
    machineman
    NO temp read out on panel just a warning triangle and the middle line on each of the digits light up, any thoughts would be welcome.M
    #187509
    Re: WHIRLPOOL S20ER Side by side F/F
    Try switching off for 5 seconds and switch back on. As this is the “timer” with the rear PCB being the “controller” I’d go for faulty timer, ie new display required.
    hope that helps
    Kevin
    #187510
    machineman
    Do you mean switch the mains off for 5 secs,and whats with the triangle.m
    #187511
    Yes the mains, the triangle I’ve never seen, I’d have to think it’s not a rear pcb generated fault therefore it’s the display at fault.
    Kevin
    #187512
    machineman
    called today switched off then back on dispay ok set for -18 and 5 cust said she had to keep f/f switch on to keep freezing .the little triangle is a warning light when temp to high. works for about 20 mins alarm goes off little triangle lights up .only centre digits off freezer temp alight fridge digits ok at 5.any ideas welcome and would you still go for display board .M
    #187513
    DentedPorsche
    No, it’s an error code being displayed. Double dashes in the freezer display indicate the temperature has risen above -13.
    Check that the compressor fan is running, compressor not overheating and cutting out. Main PCB may be the culprit. Don’t have the manual to hand just now but if no one else comes along with the answer I’ll dig it out tomorrow after work.
    Brian
    #187514
    machineman
    Not the comp it runs normally on fast freeze,M
    #187515
    DentedPorsche
    OK, got the training manual open and it says, verify that the compressor, the evaporator and compressor fan are working and measure the internal temperature. Replace the main board.
    Basically, if all checks out ok the board is at fault. No mention of the freezer probe (NTC) though. Freezer probe is the 4 way connector on the board and uses pins 1 and 3.
    Brian
    #187516
    machineman
    ok changed the main board , still icing up and not defrosting checked heater not o/c .m
    #187517
    DentedPorsche
    machineman wrote:still icing up and not defrosting
    Emmm, this is the first mention of icing up and not defrosting.
    I’ll bring the manual home again tomorrow, if no ones answered I’ll see whats in there.
    Brian
    #187518
    EFS
    If it won’t do a defrost it is probably the defrost stat on the evaporator.
    You will find it listed as “Cable harness bi-metal” 481232058132.
    About £21 trade.
    Steve
    #187519
    machineman
    whats in that little black box .m
    #187520
    EFS
    The wiring diagram shows a thermal fuse & a thermostat.
    No values are listed.
    Steve
    #187521
    machineman
    cheers thanks for the replies.m
