Hi All
This fridge freezer is giving me a bit of jip, about 3 weeks ago I was called to this unit because it had completely lost temperature control in the fridge and was intermittently tripping the electrics. I found that the diffuser had broken and the main defrost element had gone short to earth so replaced both.
Now the unit works perfectly for about a week then slowly begins to lose temperature in the fridge section, the freezer is sitting at around -20C though the display shows -18C, the fridge section shows 4C on the display but is actually around 10-12C inside, I have double checked that the new diffuser is opening and closing correctly, the air vents are clear, it appears to be defrosting correctly and the fan is running. Is this likely to be the temperature sensor or something else.
Thank you
Jem
