WHIRLPOOL SCW1112 WASHING MACHINE
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries WHIRLPOOL SCW1112 WASHING MACHINE
  • #61346
    Dapman
    Hi All,
    Can anyone help?
    This machine is a front loader semi-pro type. I believe a later version to the AWM9000 series
    Machine does not fill – soap dispenser motor operates continually.
    The front display operates normally and counts down the time.
    Have checked water valves etc.
    Any help woud be appreciated
    #345784
    Re: WHIRLPOOL SCW1112 WASHING MACHINE
    this is a long shot but based on what you are saying
    old aeg auto had similar problem
    set up progamme and press start. motor in soap draw turns to direct water to correct draw. when motor stops machine fills
    motor turns until a contact is made feeding back to the pcb and telling it to stop motor (probably)
    sounds much the same. this motor will turn until it reaches correct point. motor will keep turning if
    bad contacts within soap draw motor unit
    bad connections to soap draw motor unit
    faulty pcb
    hope this helps
