Whirlpool semi integrated dishwasher
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Whirlpool semi integrated dishwasher
  • #57550
    lyndy
    Help would be appreciated:
    Whirlpool Semi Integrated Dishwasher
    Model: ADG6340WH
    Serial no. 854233215710
    Water starts fill ok – spray arms working ok.
    Powder disperses ok.
    Machine stops after powder is dispersed – small amount of water remains inside.
    On/off button flashes continuously.
    Machine empties when on/off button is held down.
    Machine will restart but only do as described above – will not go through programmes.
    Any advice?
    #331528
    A1engineer
    Re: Whirlpool semi integrated dishwasher
    count the flashes (eg flash, flash, flash pause flash, flash, flash, pause, is f03 heater) its telling you a fault code
    if it is a contant flash it might be f01 which iirc is ntc fault.
    #331529
    lyndy
    Customer has said it flashes six times then a pause, six flashes then pause….
    #331530
    look in known error codes its there
    lyndy
    Where do i find this?
    #331532
    open trade tech forum at the top is a load of sticky posts that always stay at top for common information
    on is called known error codes
    http://www.ukwhitegoods.co.uk/modules.p … topic&t=40
    all this type of info is in there
    on these types of forums you have to learn to dig about most questions have been asked before so if you can find it than the job gets sorted quicker
    rolf
    six flashes is water tap closed. If there is some water going in as you stated it’s more than likely the flow meter.
