Whirlpool semi-pro dryer (3RAWZ481EML2)
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Whirlpool semi-pro dryer (3RAWZ481EML2)
  • #101932
    SWERV
    I have looked at the above dryer, the reported fault was no power just a ticking noise.
    When you press the start switch, the relay kick in and you can hear the timer motor tick away. Other than that it doesn’t do anything else.
    There is a fuse in the top of the harness which is ok. All of then thermal cut outs are ok, including the thermal fuse. The belt is also in tact.
    I have little experience in this type of dryer and was running short of time, but are there any known issues that I should look for when I return?
    Merv
    #486769
    well motor is the first place to check
    nothing happens on this unit till the motor starts. the heater wont switch on till the motor is revolving and the cetrifugal switch activates
    also double check the belt break switch
    dunston
    Has this model got a 196* thermal fuse (not resettable) in line with the belt switch?
    #486771
    SWERV
    It does list a not resettable thermal fuse on the parts list. Is this different to the one on the front of the heater duct?
    #486772
    SWERV wrote:It does list a not resettable thermal fuse on the parts list. Is this different to the one on the front of the heater duct?
    not as far as I know.
    SWERV
    I have had a look at the parts diagram and it does seem that a lot of the parts are obsolete.
    I will check out the motor switch when I go back.
    #486774
    I realise this is not your dryer but i suspect the motor and heater system will be the same. for heater just ignor its gas as the heater switch in the motor just operates the element instead of a gas valve
    https://www.manualslib.com/manual/61…page=21#manual
    you can see motor wiring on page 21
    SWERV
    Thanks Dave.
    #486776
    Hollytree_Technical
    If you take the front bottom panel off then you should find a wiring diagram attached to the inside (Note Of Caution: I have come once or twice come across the incorrect ones being inside).
    Most parts for these are available but not under the whirlpool or hotpoint UK numbers, instead you may need the numbers that are on the parts themselves.
    Assuming that the thermal fuse on the exhaust duct is good then I would set the timer to a program running position and check for continuity from the following:
    • White wire of motor up to the door switch (or Neutral).
    • Blue wire of motor up to Live (while pressing the start button).
    If these test out as okay then the timer is good, alternatively you can go the large connector block at the back of the console and test between the blue and white wires, you should get a reading of around 10 ohms (this is the circuit through the motor).
    In my experiance when the motors fail they either let out the magic smoke or buzzing loudly and blow the fuse.
    Jem
