Whirlpool side by side
  • #28129
    subs
    S20B RSB21-A/G Went out to this a couple of weeks ago with a build up of ice on the evaporator. Heater ok and the six wire “stat/overload” checked out ok (i presume this is the defrost stat, fan stat and overload cut out).No error on display so just melted all the ice. Of course, ice has now come back. Is there a test for these to see if the defrost kicks in? Anything else to try? Is it the rear board? Any advice would be appreciated.
    Subs
    #217014
    DentedPorsche
    Re: Whirlpool side by side
    Switch off at the mains, wait a couple of minutes, switch on again. It should go onto defrost mode before starting up.
    #217015
    PaulG
    Theres a test you can do on the rear module, you measure the resistance of two pins in the plugs that fit to the module, but because I’ve been out of the trade for over a year, I can’t remember which pins or what value of resistance, without actually looking at one.
    This test just tells you if everything is OK behind the evap cover, if it is OK, you may be looking at the rear module.
    #217016
    Spinfast
    Suds…
    I have the resistance and voltage readings for the Whirlpool side by side if it can be of any assistance (on jpeg).
    Spinfast
    #217017
    subs
    Thanks for all your replies! I went back to this fridge and tried the turn off and back on to see if heater kicked in but nothing. Double checked every thing, again all ok so ive ordered the rear module and hope that cures it.
    SPINFAST those readings would be handy if you could send them check your PM 🙂
    #217018
    subs
    Just to update this thread for anyone interested, I changed the rear module and it kicked straight into defrost mode and is all working fine. This fridge is only a 2005 model and has the new rear board with the beefed up capacitors etc .
    Subs 😀
