Whirlpool side by side RS20BRSB20AG
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Whirlpool side by side RS20BRSB20AG
  • #29701
    jd
    Hi there could any one help with this problem, After fitting new display pcb panel for fault of flickering display which has been successful in the past new display shows correct temp for maybe 5 seconds and faults to 00 in freezer display and flashes 00 then 0e alternatively in fridge display.
    Do i have a faulty board or is there a way of resetting it, thoughts on this much appreciated. ps sorry for the essay.
    #224170
    DentedPorsche
    Re: Whirlpool side by side RS20BRSB20AG
    Bit of a guess here.
    Machine is older than week 30 2003 and you’ve not changed the rear board.
    If it’s older then you need to change both boards as the electronics changed and they are not compatible.
    Brian
    #224171
    jd
    Thanks Brian worth a try as the board i fitted was a superceded part and i noticed the water filter light was not on it.
    will give it a go
    John.
    #224172
    DentedPorsche
    I’d check the part number of the one you got. I fitted one not long ago and it still had the filter light, mind you could be old stock.
    Brian
