Hi.
Our oven won’t get up to the correct temperature, i’ve read the posts before and im reasonably sure its the heater element. The thermostat seems to work as i heated up the oven with the grill and when i then then turned the oven and scrolled through the temperatures the temperature arrows on the front panel differed as i went up.
I’ve got the oven out, and i figure a simple resistance test with a multimeter will tell me if the element is fully broken, but not if its partially broken…..
Is there a resistance a healthy heater element would measure?
Cheers.
*edited – found out how the element comes out*
