whirlpool slimline dw
  • #35073
    onecallpaul
    service no 851108415010 machine does not drain in cycle,but empty’s fine when float switch is manually activated. Checked for blockages,customer also says it doesn’t heat, heater is fine. Couldn’t find the actual model no just the service no was on the door sticker.
    #245047
    Re: whirlpool slimline dw
    ADG659IX. It’s digital control, so presumably a board fault – the float switch just switches power direct to the pump.
    onecallpaul
    thanks will try and find part
    #245049
    4812 218 38466 – £126 list 😯 .
    Whirlpool don’t make their own slimlines – unfortunately, the quality of the diagram is so poor that I can’t work out whose machine it actually is.
    ANDYVIVO
    Should be BSH 😉
    Regards Andy
    #245051
    onecallpaul
    Thanks guys looks like another one for the scrapheap!
    #245052
    ANDYVIVO
    Twas wrong, it’s a Beko!
    Regards Andy
