Whirlpool stopping mid cycle.
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Whirlpool stopping mid cycle.
  • #54625
    12nc. 85705145270.
    Went to this machine earlier today, customer said it wouldn’t spin.
    Did the usual quick visual check, pump filter clear, motor comm clean and shiny. The only thing I could fault was a slight ‘clicking’ from the brushes although there was no sign of any damage to the comm.
    Set it to the full spin programme and it went through perfectly, a little noise from the brushes but nothing excessive. She was not sure if she had selected rinse hold so I asked her to try the machine again.
    She has just phoned back to say it has gone through the wash cycle and is now stopped midway between 10 & A on the dial, appears to have drained. 😕
    Any pointers would be welcome.
    timdowning
    Re: Whirlpool stopping mid cycle.
    Did you get her to select spin on its own after it faulted?
    As you know, it could be a timing out on drain, or is it a time-out on fill?
    You know what customers are like! Its not actually a no spin fault, its just that it hasn’t got to spin!
    Tim.
    #320373
    She did say she had tried to get it to spin but she does come across as a bit of an air head, very pleasant but a bit dizzy so anything is possible. 😉
    deltra
    had one today doing same thing. turned out to be cold inlet valve, only working 50{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of the time 😕 dont know why,it seemed ok. anyhow , machine worked perfect after changing valve(not cheap those wpool valves 😯 )
    #320375
    thankevans
    have you checked sump hose may be blocage usually socks had loads of these door seal are rubbish.
    #320376
    Sorry for not getting back, it was an item of clothing stuck round the eco ball.
    When I asked her if she had noticed it wasn’t emptying properly she said she had but didn’t think it mattered so didn’t mention it. :rolls:
