whirlpool stops mid wash
  • #35164
    AASWALES
    hi this machine is a whirlpool awm6100 and stops mid wash and the start light flashes . any clue ? thanks alan
    #245377
    DentedPorsche
    Re: whirlpool stops mid wash
    Hi Alan,
    The 85 number would give the exact model.
    However, on the one I checked the spin speed leds should be flashing to indicate the fault.
    Brian
    #245378
    AASWALES
    hi brian the customer has justa rang she said it worked untill rinse then stopped rinse light on start flashing then she pressed start it done a couple of turns the flashing again pressed start again done rinse moved to spin didnt spin start flashing spin flashing she pressed start but nothing
    alan
    #245379
    DentedPorsche
    Obvious question, did it empty the water?
    Brian
    #245380
    AASWALES
    yes but it takes a while alan
    #245381
    lerch
    If taking along to empty then check your filter / sump hose for blockages – this is a common whirlpool problem. 🙂
    #245382
    AASWALES
    hi i had a look filter a bit blocked all pipes ok but still slow so i fitted new pump customer is going to see if it fixes prob ill let u no thanks lads
    #245383
    AASWALES
    fitted pump all working fine cheers
