Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Whirlpool T/L 3RLSQ8000JQ1 HELP!!
- This topic has 9 replies, 3 voices, and was last updated 18 years, 9 months ago by
CARLJONESDAR.
July 11, 2007 at 5:00 pm #28916
CARLJONESDAR
ParticipantHELP!
Called out to this machine, not spinning motor humming. Changed capacitor (2nd hand) and left machine working ok.
Had to call back next day as machine not spinning again. Same fault motor humming, capacitor had been cooked . Changed capacitor again (new this time) and left machine working.
Called back again! same fault, capacitor cooked. Replaced motor and capacitor and again left machine working.
Called back again today, same fault capacitor cooked.
What am I missing?
Anyone have any ideas
July 11, 2007 at 6:00 pm #220632maltheviking
ParticipantRe: Whirlpool T/L 3RLSQ8000JQ1 HELP!!
CARLJONESDAR wrote:HELP!
What am I missing?
Have you checked the supply voltage?
July 12, 2007 at 7:53 am #220633CARLJONESDAR
Yes, no problems there.
July 12, 2007 at 8:29 am #220634maltheviking
Timer trying to reverse motor at the wrong time? Gearbox seizing? It seems that the Cap. is under strain, motor running on start windings longer than it should?
MJuly 12, 2007 at 4:18 pm #220635CARLJONESDAR
Thanks, think i’ll have to change the cap again then sit and watch it for a few hours to see whats going on.
July 12, 2007 at 5:35 pm #220636maltheviking
Keep us informed 😉
July 14, 2007 at 9:00 am #220637CARLJONESDAR
Changed cap yesterday, sat and watched machine for over three hours, worked fine!
Can’t see how it could be the timer as the live to the cap goes through the switch on the motor that is open when the motor is running.
Changed gearbox, think this could be the only cause.
Will let you know after weekend if I get a callback or not.
Thanks for your help
July 17, 2007 at 8:18 am #220638CARLJONESDAR
Called back to machine yesterday (Monday), same fault. Going to order timer today.
Will let you know what happens next.July 17, 2007 at 8:57 am #220639EFS
I make that 4 capacitors,1 motor,1 gearbox and a timer to come. 😯
Surely a new machine would cost lessSteve
July 17, 2007 at 10:36 am #220640CARLJONESDAR
One new cap, three s/hand caps, one s/hand motor and one s/hand gearbox. New timer on order.
There own motor and gearbox will be refitted with new timer. Will only charge when machine is ok and only for parts needed. -
