whirlpool t/l no-go
  • #50769
    petalpop
    model 3lsc8255eq1 top loader
    no go at all
    checked power to socket + fuse
    lid switch makes good click so presumed ok as cant find where wires go to
    is there an obvious fault on these as its the 1st fault on one i have seen
    please help
    #305913
    geoff1
    Re: whirlpool t/l no-go
    In the recent ones I have had there was a 6.3ma 20mm fuse in an in line fuse holder within the wiring of the control panel. You may also find a wiring diagram there as well. If this fuse goes the machine will be totaly dead.
    HTH
    Geoff
    #305914
    petalpop
    what blows the fuse
    or is it just like a light bulb and just blows given time
    #305915
    petalpop
    i can find a 63ma 20mm timelag fuse is that it
    #305916
    geoff1
    Yes it will be a 6.3amp sorry I said 6.3ma but it will be 6.3amp
    Mine was the motor taking to much power causing it to blow. I am sorry I do not know of any common faults causing the fuse to go but start with the motor and cap
    Geoff
    #305917
    petalpop
    ok cheers
