Whirlpool TD AWZ 8477 Not Drying
Have tested heater that’s ok and the wires from the programmer to the heater the 3 brown & the 2 white ones, they are all fine, the heater does get a little warm to the touch when the machine is run with the back off.
Do the 2 white wires to the heater go to a stat I could not see, if so could it be this that is causing the problem and is it a common fault?
If not any suggestions please
Bernie
I have just posted this by mistake as a Hoover VHC180 it should have been this Whirlpool sorry.
