whirlpool timer blown
Viewing 12 posts - 16 through 27 (of 27 total)
  • #394015
    davelerave
    Re: whirlpool timer blown
    thanks
    seems to be working fine
    one snag
    i stopped it just before the fast spin at the end of the daily load cycle
    i mixed up the belts
    one seems slightly loose and i fitted the tighter one
    however i thought maybe the drum was shaking a bit too much so i stopped it as i dont want to **** up at the last minute
    how would i know ?? :eeek:
    the loose one fits but slides off a little easy
    i’ll do some checking myself online before i run it again
    #394016
    Specialist01269
    Dave: Did you put a load of clothes in when you tried it ?
    #394017
    davelerave
    no it’s not quite a full load
    seems to be about 2/3
    thanks
    #394018
    davelerave
    i’ve just put on the remainder of the cycle at 1000rpm
    i was looking at the machine with the lid off before so i may have been confused slightly
    the drum shakes quite a bit on spin
    but there’s only a mild vibration off the machine itself
    it doessn’t seem excessive with the lid on
    is there a way to confirm the correct belt
    #394019
    Specialist01269
    Hi: When you say 1 was loose, how loose was it ? normally you’ve got a bit of play in the longest side of the belt but not excessive. Before you tried the machine did you make sure it was level ? Also check the suspension to make sure nothing jumped out when you were tilting the machine over.
    #394020
    davelerave
    hi
    i confirmed the belt was correct by re-assembling spares machine and comparing
    the belts have a part no. alright but i couldn’t match it to the whirlpool model
    machine is level
    and i’ll double check suspension in morning
    tbh the shake is just temporary at the lower speed
    minimal drum shake and machine vibration at the higher speed
    so it should be ok
    the belt meanders in and out on the drum slightly
    is that normal?
    i don’t spend much time fitting it except to get the vertical alignment correct ?
    thanks again for the assistance
    #394021
    Specialist01269
    Hi Dave: On some machines you’ll see a very small amount of movement. If it’s more than slight you need to check that everything is lined up properly, is it the belt moving or a slight wobble in the drum pulley ?. If your happy that it’s running with no problems give it a try with a couple of loads just to make sure the belt stays on, if it does then box it all up & give yourself a pat on the back mate.
    #394022
    davelerave
    the drum shakes a bit when accelerating
    the machine doesn’t
    and yes the belt moves slightly in and out on the drum pulley-but not much
    i’ll prob wrap it up at this stage today as i’m happy enough with it
    thanks for walking me through it
    much appreciated
    #394023
    Specialist01269
    :tup: Your more than welcome mate, glad you got it sorted out. Thanks for letting me know that you got it finished, a lot of people would’nt bother.
    Anything else we can help with please let us know.
    #394024
    davelerave
    all been well now after about 10 washes
    belt and drum seem fine
    i had to replace the front control panel
    the old one seemed to be damaged
    the new one is for a 1400 spin machine(1000,1400)
    whereas my machine was 1000,1200
    i wasn’t sure about that so i’m using the 1000 rpm setting
    #394025
    Specialist01269
    Hi Dave: Glad to hear it’s still going ok for you, run it at the 1,000 for a while to see how it goes. You should’nt have any problems with the 1400, you changed everything over to your machine. What was the problem with the other panel ?
    #394026
    davelerave
    thanks not sure
    the ‘daily load’ neon wasn’t illuminating when i selected it which is the cycle i had it on when it blew so i didn’t wan’t to take any chances
    the machine is a 1200 spin but the replacement control panel is 1400 spin
    these whirlpool timers have a model number and also a 3-digit identification number-385 in my case
    is that correct? and how difficult are these to source
    it seems surprising that they aren’t properly protected against damage from faults
