whirlpool top loader
  • #27979
    petalpop
    model3lsr6233eq
    there is a white plastic piece between the motor and gearbox
    is it available seperate or do you need a complete gearbox?
    either way could i have a part number please
    #216387
    ANDYVIVO
    Re: whirlpool top loader
    “clutch” (2 pieces of plastic and rubber) 481932528035 £8.15 in stock @ Masterpart
    Regards Andy
    #216388
    petalpop
    cheers mate
    #216389
    petalpop
    i have the gearbox coupling now and need some advice
    do you have to take the gearbox off or does the motor/pump come off easier???
    #216390
    clivejameson
    Simplicity….two 1/4in headed screws hold spring brackets to clamp the motor to the gearbox…remove screws and prise off brackets, the motor drops off (unplug wiring harness at motor block)
    Be careful not to break the new coupling, they are a tight fit on the respective shafts….i usually ‘persuade’ them on with an old 13mm socket tapped gently with a small hammer 😉
    #216391
    petalpop
    cheers that is a relief
    thought i would be spending hours stripping the gearbox
    #216392
    EFS
    The part number is correct but if you just order a clutch you may get something else.
    The new drive coupling now has a metal insert in the plastic moulding which means it will last longer before splitting.
    Bad news. 😥
    Steve
    #216393
    maltheviking
    Take the cabinet off to make the job easier, if you have the space to do it that is 😉 only takes 5 mins to do. :rolls:
    There are a few pickies in this web site, might be of interest 😉 http://www.cheapapplianceparts.com/washer_repair.htm
    #216394
    clivejameson
    Bad news. 😥
    Steve
    I’ve only seen one that split!…all the other failures i’ve seen are where one or two of the teeth have stripped off 😉
    I’m sure it’s designed to be a weak link anyway to protect the gearbox/agitator if a big load jams in the drum?
    #216395
    petalpop
    yeah rubber had worn and then (cause of play) lugs had snapped
