Re: Whirlpool top loader 3RLSQ8000JQ2 Oil on the coupling
I haven’t had to replace the seals in one of these gearboxes but I have stripped one down, they are not that difficult to do but are easier done on a workbench with a tray to catch/drain the oil into.
The part No’s for the seals are:
481953278121 Motor Coupling seal
481946669833 Inner output shaft gasket
481946669834 Outer output shaft gasket
481939038023 Sealant for the two body half’s (I think)
PM me an e-mail address and I can send you a copy of the Direct Drive Manual which goes into detail of how it works and I can also send you an exploded diagram for the gearbox.
Jem
