Whirlpool top loader
  • #37421
    williemac
    Model number3rlsQ8000jQ5
    Machine is draining ok washing ok but is not doing final spin,gearbox seems ok motor seems ok has anyone came across this problem before thanks?
    #255061
    msappliance
    Re: Whirlpool top loader
    i think this machine has a plastic link between motor and gearbox. this link breaks.
    remove pump then motor and you should see 2x 3 legged peice of plastic joined by rubber mount check for wear.
    #255062
    THIS should be what you need.
    williemac
    changed gearbox,motor and coupling drive (link) still no joy.any other suggestions thanks
    #255064
    bzz67
    had one once that got me for a while, the drum was dropping down and touching ther outer tub. the cylinder clamp between drum and shaft had worn the top lip clean off, because i had never seen this before i could’nt see the fault.
    hope this helps!
    #255065
    when you say you changed the box does this include the spin clutch on top of the box had a few of these fail
