Whirlpool Top loader (fills then stops)
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Whirlpool Top loader (fills then stops)
  • #101247
    matrixresonator
    Don’t usually do toploaders but a local charity has asked me to look at one.
    On a wash cycle it fills up then nothing.
    If I put it on drain/spin it empties and the motor kicks in so both of those are fine. Any ideas?
    Whirlpool MFG Date 2019.
    Mod 3LWTW4705FW0
    Ser C91920205
    #483990
    is it silent on wash or does the motor run
    if you want to see a parts list
    https://www.partadvantage.com/lookup/252029/1661916#diagram
    Hollytree_Technical
    Its possibly a problem with the mode shifter but if you let me have an email address then I can send you the service info.
    Jem
    #483992
    matrixresonator
    electrofix wrote:is it silent on wash or does the motor run
    SIlent, its like everything has stopped. My 1st thought was capacitor but it drains and spins fine on the spin cycle. Thanks for the diagram link.
    Hollytree_Technical wrote:Its possibly a problem with the mode shifter but if you let me have an email address then I can send you the service info.
    Jem
    That would be great thank you, I’ll send a message with my email.
    #483993
    matrixresonator
    From what I can find the shifter is C00509300 but nobody seems to stock it over here?
    #483994
    Hollytree_Technical
    I have just sent you the service info.
    The shifter has got an optical sensor on it so it may be worth double checking that it is clean, also take the shifter off and try moving the mechanism by hand to make sure it isn’t bound up.
    Jem
    #483995
    matrixresonator
    Received thanks, its only a few minutes from my house so I’ll pop tomorrow and take it off and see what I find.
    #483996
    Hollytree_Technical
    Also try the test mode – it can be little finnicky to get into at times but works quite well and is usefull for finding out what does and doesn’t respond.
    Jem
    #483997
    matrixresonator
    Looks like I’ve found the issue.
    Put it in manual test mode, fills OK when testing hot valve but nothing on cold valve, checked voltage and feed to the valve is good so now just need to track one down
    #483998
    matrixresonator
    This is the only one I can see, long shot but does anyone have one kicking about anywhere?
    https://www.ebay.co.uk/itm/225153872813
    #483999
    cant you swop a coil from another valve
    big problem with these is finding the british part no. in this case found the answer on Aswo
    look up part no C00519528 I think it looks correct but getting some silly prices
    Aswo list it at £76 plus vat etc but 3 to 4 weeks delivery
    matrixresonator
    electrofix wrote:big problem with these is finding the british part no. in this case found the answer on Aswo
    Yeah I’d seen that on ASWO but was hoping to find something a bit quicker as its for a special needs care home. Fortunately they have a couple of other (albeit smaller) machines.
    #484002
    I would try swopping the valve coil
    much cheaper and quick
    matrixresonator
    Yeah think that’s going to be the route
