Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Whirlpool Top loader (fills then stops)
- This topic has 15 replies, 3 voices, and was last updated 3 years, 5 months ago by
matrixresonator.
October 11, 2022 at 5:08 pm #101247
matrixresonator
ParticipantDon’t usually do toploaders but a local charity has asked me to look at one.
On a wash cycle it fills up then nothing.
If I put it on drain/spin it empties and the motor kicks in so both of those are fine. Any ideas?Whirlpool MFG Date 2019.
Mod 3LWTW4705FW0
Ser C91920205October 11, 2022 at 8:35 pm #483990electrofix
Moderatoris it silent on wash or does the motor run
if you want to see a parts list
https://www.partadvantage.com/lookup/252029/1661916#diagram
October 11, 2022 at 10:09 pm #483991Hollytree_Technical
ParticipantIts possibly a problem with the mode shifter but if you let me have an email address then I can send you the service info.
Jem
October 12, 2022 at 6:05 am #483992matrixresonator
Participantelectrofix wrote:is it silent on wash or does the motor run
SIlent, its like everything has stopped. My 1st thought was capacitor but it drains and spins fine on the spin cycle. Thanks for the diagram link.
Hollytree_Technical wrote:Its possibly a problem with the mode shifter but if you let me have an email address then I can send you the service info.
Jem
That would be great thank you, I’ll send a message with my email.
October 13, 2022 at 8:19 pm #483993matrixresonator
ParticipantFrom what I can find the shifter is C00509300 but nobody seems to stock it over here?
October 13, 2022 at 8:36 pm #483994Hollytree_Technical
ParticipantI have just sent you the service info.
The shifter has got an optical sensor on it so it may be worth double checking that it is clean, also take the shifter off and try moving the mechanism by hand to make sure it isn’t bound up.
Jem
October 13, 2022 at 8:51 pm #483995matrixresonator
ParticipantReceived thanks, its only a few minutes from my house so I’ll pop tomorrow and take it off and see what I find.
October 13, 2022 at 9:17 pm #483996Hollytree_Technical
ParticipantAlso try the test mode – it can be little finnicky to get into at times but works quite well and is usefull for finding out what does and doesn’t respond.
Jem
October 14, 2022 at 10:22 am #483997matrixresonator
ParticipantLooks like I’ve found the issue.
Put it in manual test mode, fills OK when testing hot valve but nothing on cold valve, checked voltage and feed to the valve is good so now just need to track one down
October 15, 2022 at 6:11 am #483998matrixresonator
ParticipantThis is the only one I can see, long shot but does anyone have one kicking about anywhere?
https://www.ebay.co.uk/itm/225153872813October 15, 2022 at 9:25 pm #483999electrofix
Moderatorcant you swop a coil from another valve
October 15, 2022 at 9:48 pm #484000electrofix
Moderatorbig problem with these is finding the british part no. in this case found the answer on Aswo
look up part no C00519528 I think it looks correct but getting some silly prices
Aswo list it at £76 plus vat etc but 3 to 4 weeks delivery
October 16, 2022 at 7:31 am #484001matrixresonator
Participantelectrofix wrote:big problem with these is finding the british part no. in this case found the answer on Aswo
Yeah I’d seen that on ASWO but was hoping to find something a bit quicker as its for a special needs care home. Fortunately they have a couple of other (albeit smaller) machines.
October 16, 2022 at 7:34 pm #484002electrofix
ModeratorI would try swopping the valve coil
much cheaper and quickDave
October 16, 2022 at 8:11 pm #484003matrixresonator
ParticipantYeah think that’s going to be the route
