Whirlpool Top Loader – Identification Needed
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Whirlpool Top Loader – Identification Needed
  • #57935
    Hollytree_Technical
    Hi All
    I have been asked to fix a Whirlpool Top Loader but cannot find a model number on it anywhere and wondered whether you could help me identify it please. Here is a grainy image (Sorry taken on phone in poor light) of the control panel:-
    The only information that I can glean is some part numbers as listed below:-
    Motor 3950297
    Timer 3954781
    Control Panel (White) 8318455
    Control Panel (Biscuit) 8316033
    Pressure Switch 3366845
    Control Panel Cover 8318789
    End Cap 1 (White) 8271363
    End Cap 1 (Biscuit) 8314851
    End Cap 2 (White) 8271369
    End Cap 2 (Biscuit) 8314852
    The Writing on the front of the machine says:-
    “Whirlpool Ultimate Care 2”
    “9 Cycles, 4 Speeds”
    “Quiet Wash Plus”
    “Whirlpool Gold American Collection”
    I think the clutch has gone in this machine (It releases the brake but won’t spin the drum unless you start it by hand) but need either a part number or model number for it otherwise the parts suppliers can’t help me.
    Thank you
    Jem
    #332730
    EFS
    Re: Whirlpool Top Loader – Identification Needed
    Clutch is common to the whole model range 481969018152 🙂
    Steve
    #332731
    chezza
    Just for reference, the model and serial numbers are on a plate where the lid pivots …. lift the lid, scrape away 8 years of crusted soap powder ( taking care not to scrape the label away at the same time 😆 ) … et voila
    #332732
    don
    Resized the image for you Jem 😉
    Don 🙂
    #332733
    work on the general model of: 3RGSC9455 much of the drivetrain is the same across the range, pumps and door switches differ IIRC
    #332734
    Hollytree_Technical
    EFS wrote:Clutch is common to the whole model range 481969018152
    Thats the bit – good to know that I can’t go far wrong then.
    chezza wrote:Just for reference, the model and serial numbers are on a plate where the lid pivots
    If only – the lid is clean as a whistle but there is no plate that I can find on it just a big label saying when to use what wash powder/programme.
    don wrote:Resized the image for you Jem
    Thank you will have to learn how to do that.
    eastlmark wrote:work on the general model of: 3RGSC9455 much of the drivetrain is the same across the range, pumps and door switches differ IIRC
    Excellent – that means that I can finally bring a up a list of parts with some chance of finding the right bit and from all the normal suppliers.
    Thank you all
    Jem
    #332735
    chezza
    it will be . lift the lid to 45 degrees , then look along the rim , usually just above the spout that chutes the water into the tub ….
    but as the others state , clutch is very common to all the versions .
    and this http://appliancejunk.com/forums/index.php?topic=6428.0 will tell you how to do it ( video demo on the 1st page )
    #332736
    check for oil leaking out of the gearbox contaminating the clutch
    very simple to drop box and check take about 15 mins
    Hollytree_Technical
    Thank you all for the help – went back yesterday afternoon with a clutch mech, there was no oil contamination on the old one that I could see (Would have some trouble getting the oil in there as it is above the gearbox and facing the wrong way), Comparing the pads on the clutch bands there was a thickness difference between the two of about one third, changed the clutch and it now works.
    I forgot to take the camera with me which would allow me to take better photos of it, I had a good look for a model number but I am either being very dense or it doesn’t have one on it.
    Thank you all
    Jem
    #332738
    Hollytree_Technical
    After doing more research I found a table that tells me how whirlpool makes the model numbers, putting the data that I do know into the table gives me “??G?C94???Q”, when I then put it into SIOS then the only machine that matches that data is “3RGSC9455JQ” (the same machine as eastlmark said). 😯
    Unfortunately I have had a call back to it as it won’t spin under load (they didn’t have anything to put into it when I was there with the new clutch), it does spin when empty (which is an improvement on when I first saw it) – has anyone got any more ideas as to what could be causing this?
    Thank you
    Jem
    #332739
    Hollytree_Technical
    Had a look at this one again this morning – it won’t spin with a load in the drum but it will without, the new clutch looks fine though it feels like it is getting hot (should it get hot?), I am wondering now whether it also has a gear box fault (though it feels like there is no slip at all when I turn it by hand) or whether the bearings have gone (though it is not noisy and again feels ok turning it by hand). I am a bit stumped by this one now and would appreciate any help/guidance that you guys/girls can give me.
    If it is a gearbox fault then I guess that I will need to replace/top up the oil – what oil is suitable for this?
    If it is a bearing fault then what tip/trick is there to undoing the notched nut that holds the drum down or is there a suitable tool that I can buy in this country that will fit it?
    Thank you
    Jem
