3rgsc9455jq3. Third time i have seen this one for no spin. Since removing an item from between the drums, i cannot seem to tighten that centre shaft clamp enough to stop the drum sliding down the shaft after a few washes.
do you know any tricks to stop this from happening or should i replace the clamp.
never usually have problems fixing these but this one is becoming a pain.
Re: whirlpool top loader inner drum keeps dropping
thanks again, job done, easy when you see the new one. can,t believe that much had worn off the old one without trace. still won,t catch me out next time.
cheers.
