Whirlpool Top loader tap adapter
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts Whirlpool Top loader tap adapter
Viewing 5 posts - 16 through 20 (of 20 total)
  • #448745
    Brendarran
    Re: Whirlpool Top loader tap adapter
    I have the adaptors in stock but you are looking at around £25 for a pair if my memory serves. I’m away at the moment but will be back home tomorrow night. If you give me a call on 07956324546 i will dig some out for you and get a more accurate price.
    #448746
    Twoten wrote:Interesting; what are you suggesting? I cut a 3/4 bsp thread over the 3/4 NPT thread on the valve?
    A little jokingly perhaps but yes. Though cutting metal would be a possibility, on a plastic valve thread, not so. :snig:
    #448747
    Brendarran
    Just checked and I can do them for £25 to your door.
    #448748
    Twoten
    Brendarran wrote:Just checked and I can do them for £25 to your door.
    I will PM you.
    #448749
    EFS
    I have seen lots of these machines which after many years of use have needed new inlet hoses due to deterioration.
    Due to cost and non availability of spares I fit a standard 3/4 bsp hose which does away with the need for the adaptor which is only for the tap end.
    The thread on the inlet valve is not too dissimilar to 3/4 bsp and it will go on ok and no need for PTFE tape as the seal is on the rubber washer and not on the threads.
    Not all hoses are the same and some fit better than others so maybe try a different make.
    Steve
