Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Whirlpool Toploader 3rlsq8000
- This topic has 5 replies, 3 voices, and was last updated 11 years, 4 months ago by
HandyTimo.
December 9, 2014 at 11:47 am #83348
HandyTimo
Participanthi all, ive fitted a new drive coupling and clutch assly to this machine. all goes well mthe machine starts to spin but after about 30 seconds a plumb of smoke comes out of the bottom and the machine stops, any ideas are much appreciated thanks
December 9, 2014 at 1:47 pm #422498admin
KeymasterRe: Whirlpool Toploader 3rlsq8000
All you’ve got there is the motor at the bottom.there is also a control fuse behind the control panel
Bryan
December 9, 2014 at 3:01 pm #422499Hollytree_Technical
ParticipantRe: Whirlpool Toploader 3rlsq8000
Does the drum rotate when it goes into spin?
Is it happy when doing the wash cycle? I.e. agitator twisting back and forth with drum staying still.
Are the drum brakes releasing properly, if not then they could be the cause of smoke.
Is the motor getting red hot?
You should be able to run the machine with the cabinet off, this will let you see where the smoke is coming from.
Jem
December 9, 2014 at 10:54 pm #422500HandyTimo
I will take the cabinet off as suggested. The drum struggles to even agitate let alone spin now. Possibly brake issue, meaning they have ceased the drum in place. The the temperature of the motor does not exceed what I believe to be normal.
I will investigate and feed back,
Apprechiate the replies guys,
Timo
December 9, 2014 at 11:49 pm #422501Hollytree_Technical
The brake should only affect the spinning of the drum not the agitation of the agitator.
Draw a line on the side of the clutch to make it easier to see if it is moving.
It is also worth checking for jammed washing between tub and drum as that will stop it spinning.
Jem
December 10, 2014 at 2:53 pm #422502HandyTimo
The drum seems to move freely anti clockwise then jams until I apply a lot of force to free the tub. It jams completely and is very hard to move clockwise. I’ve checked between the tubs and there is no washing to obstruct movement.
Everything on the clutch has been swapped out with what Whirlpool supply in the kit (everything apart from the metal housing,)
Do you think it could be an issue with the transmission / gearbox ? I seem to recall it uses a different cog for if it is agitating or spinning,
Timo
