whirlpool toploader 3RLSQ8000JQ
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts whirlpool toploader 3RLSQ8000JQ
  • #47310
    washtec
    I went to this washer a few years ago and found that it needed the hose from the pump to the drain hose 9it had been rubbing on the floor, so I ordered one and found that the drain hose that I ordered was the wrong one and didnt fit all the way to the pump but just to the back panel of the appliance, I eventually got the right one after lots of faffing around.
    3 years on and the same thing has happened again and I am wondering if anyone knows what this hose (from the pump to the back panel) is called. the memories have all flooded back..why didnt i keep a note of the part number i will never know, but i will this time.
    any help would be appreciated, thanks
    paul
    #293033
    Re: whirlpool toploader 3RLSQ8000JQ
    4819 033 59816
    washtec
    Thanks Chris for the swift reply, i really appreciate it.
    paul
    #293035
    washtec
    Thanks for the part number chris, would you have a description as the number is not recognised on whirlpools website or connections.
    or here http://www.whirlpoolparts.ca/parts/fspS … 1&folder=& , the hose exits at the bottom of the appliance not at the top
    cheers
    paul
    #293036
    That’s the p/no from the SIOS disc – it’s just described as “hose”. The illustration clearly shows it going from the pump outlet to a tubey thingy at the bottom of the rear casing. List is showing as £33.27 on the disc.
    In stock at Masterpart, £31.
    washtec
    Thanks Chris for all your help.
    paul
