Whirlpool Toploader 3RLSQ8033SW0 overfilling
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Whirlpool Toploader 3RLSQ8033SW0 overfilling
  • #65062
    conormccleane
    This machine is overflowing. Disconnected pressure switch and blown thru’ the air hose into pressure chamber and seems fine. Also blown from pressure chamber to pressure switch and no holes evident in tube.
    I blew into pressure switch on a test fill and water stopped and drain pump came on (which is OK?)
    When filling, the water flow almost stops, but then the flow starts again in a cyclical manner until tub is full.
    Is this a holed diaphragm in pressure sw or what?
    Thanks,
    Conor!
    #359038
    spimps
    Re: Whirlpool Toploader 3RLSQ8033SW0 overfilling
    Useing a different or new tube actuate the pressure by blowing in the tube,then kink it at the end and fasten it to see if the presure switch does hold and not re set,chafing of the tube is also a possible cause
    #359039
    conormccleane
    thanks spimps,
    nice method, will try it out
    conor!
