Whirlpool Tumble Drier AWZ 2650 not dryng properly
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Whirlpool Tumble Drier AWZ 2650 not dryng properly
  • #73087
    Windjammer
    This drier’s performance has badly deteriorated and its drying cycle has to be extended to dry washing properly.
    I have cleaned the filters.as usual, and checked the two thermostats and heater for continuity and they appear to be ok, although one heater connection has clearly over heated at some time.
    Any advice on this problem would be appreciated.
    #386388
    andyjawa
    Re: Whirlpool Tumble Drier AWZ 2650 not dryng properly
    Cannot fInd AWZ2650 listed anywhere, weird! The heater tags are well known as rubbish, cut them off and re tag would be a good start. There is another thermostat on most w/pool machines other than the 2 ones on the element- do know what yours looks like of course- the vented type have a stat towards the front of the plastic base accessible by removing the drum and the only other one is the condenser type where the stat, from memory is via a plastic panel from the front- ages since I worked on any w/pool t/dryer so take note!
