whirlpool tumble dryer Awz7303
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum whirlpool tumble dryer Awz7303
  • #64256
    jimmy mouse
    i have no heat in the dryer i have tested the element and the two thermostats either side of it which read infinite and i have tested the blow thermostat which reads open circuit am i right in saying the blow thermostat is faulty? if so where can i get one. i live in bury
    #356536
    Re: whirlpool tumble dryer Awz7303
    stats should read short circuit
    element will have a resistance below 100 ohms
    stats available here
    http://shop.ukwhitegoods.co.uk/Tumble+Dryer+Parts/Whirlpool+Spares/Thermostats/481225928681+Tumble+Dryer+Thermostat+Kit.html
    #356537
    jimmy mouse
    thank you for ansering my post are you seying it is the 2 stats with the element that are readin infinety on the buzzer setting and not the outlet stat that is reading open circate on the same setting and if so how mutch are they 😀
    #356538
    both stats should buzz when on buzzer setting
    element should read under 100 ohm on resistance scale
    if element is reading infinity its dud
    if stats read infinity they are dud
    jimmy mouse
    Hi dave imm sorry when i sey infinty i meen they buzz so what i ment is thee element and the 2 stats ether sid of it buzzed but the outlet stat dident and when tested with power ther was no power going to or from the element or the stats ether side but ther was power going to but not from the outlet stat
