Hi, I have a wirlpool AWZ7913 condensing dryer, I suspect the control board has given up th ghost but I’m hoping you can tell me I’m wrong!
The symptoms are no heat but motor action is fine.
I connected a meter to the heating element supply (before the overheat stats) and when a cycle is started I am getting full mains voltage for ten seconds then I can hear a relay drop out and the supply disappears.
I have already eliminated the NTC in the element and the NTC in the exhaust duct, I have also disconnected the humidity sensor but all to no avail.
The symptoms repeat every time I try it.
Am I right, is it the board or am I missing something?
Thanks chaps
