Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Whirlpool tumble dryer fuse
- This topic has 8 replies, 5 voices, and was last updated 15 years, 7 months ago by
mic.
September 8, 2010 at 8:39 am #57098
mic
ParticipantHave been to a Whirlpool tumble dryer 3RAWZ4481 a number of times. The internal fuse blows very intermittantley (after a number of months) has anyone any ideas.
September 8, 2010 at 4:16 pm #329799iadom
ModeratorRe: Whirlpool tumble dryer fuse
Moved to Trade Tech. 😉
September 8, 2010 at 9:20 pm #329800leavemetogetonwithit
ParticipantRe: Whirlpool tumble dryer fuse
I think that’s a big commercial job? If so, is it a thermal fuse? If so, it may say on the panel just above where it’s situated to also change one of the stats when it goes (the one next to it, IIRC.) I didn’t see that instruction label until I’d been to a machine about three times.
Still, just as likely to be an airflow problem. People are inclined to neglect the need for a big fat aluminium vent hose with a short run to an unobstructed outlet.
Mike.September 8, 2010 at 9:29 pm #329801cornwell40
Is this the fuse in the loom at the top.
Was advised years ago by an ex Whirlpool engineer, that there is (if I remember) a 6A fuse which regularily goes, was told to up the rating slightly.
Have only done this once when a similar fault happened and it has worked merrily for years. Meggered all the usual suspects at the time and all tested perfectly.TC
September 8, 2010 at 9:31 pm #329802leavemetogetonwithit
I think that’s only in the washers.
Mike.September 8, 2010 at 10:21 pm #329803iadom
I’ve done one in a dryer exactly as TC says, 😉
September 9, 2010 at 4:35 am #329804chezza
cornwell40 wrote:Is this the fuse in the loom at the top.
Yep , that is the advice from tech , assuming everything tests ok
September 9, 2010 at 5:57 am #329805mic
Thanks for your help, it is a 6.3 time delay in the loom at the top will try as you suggest. It all meggers ok and runs for months at a time with no problems.
Mic
September 10, 2010 at 8:34 am #329806cornwell40
Any ideas what causes it? Unbalanced loads maybe?
TC
