Whirlpool US Style Wash M/c 3RLSQ800 Fuse
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts Whirlpool US Style Wash M/c 3RLSQ800 Fuse
  • #10369
    laurenceuk
    Hi Folks,
    I am trying to identify a fuse situated behind the control panel of this machine. I have not seen it but the customer describes it as a `slow time lag` fuse. It has the following info on the ends of the fuse: BUSS T63AH25V0 and is the size (approx) of a 13A fuse.
    Apparently it has been changed before (not recently) and the eng. just changed this component and was observed doing so. They are now changing it themselves (Nursing Home). I have looked on SIOS but cannot see it.
    Thanks in anticipation.
    Laurence
    #139674
    Dave_Conway
    Re: Whirlpool US Style Wash M/c 3RLSQ800 Fuse
    T6.3A 20mm fuse Laurence.
    #139675
    laurenceuk
    Thanks Dave.
    Laurence
    #139676
    johnmac11
    Hi Laurence,
    Whirlpool no longer supply these fuses but any 6.3a 20mm slow blow fuse will do.
    I seem to get a lot of these in nursing homes and fault is usualy down to them selecting a small wash load and then cramming the machine to the top with washing. Nursing home owners want to save cash on the water bill.
    John
    #139677
    laurenceuk
    Thanks John,
    I mentioned the overloading on small load setting and was told this may be the cause as staff don`t always change setting.
    Thanks again for your response
    Laurence
    #139678
    SparkyP
    Hi Guys
    They also changed the fuse holder on these ones. If it has a black one it needs changing to the clear one which you thread the wire thru first then screw it into a metal end. Then the spring to tension the fuse. Result no more blown fuses.
    Sparkyp
