Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Whirlpool USA T/D Parts Required
- This topic has 4 replies, 2 voices, and was last updated 19 years, 9 months ago by
7390ROBERTS.
July 7, 2006 at 9:18 pm #18983
7390ROBERTS
ParticipantCan anybody tell me where i can get parts for this model please
3LER5436EQ0 MH3814220
Resistor Part No GAAP0500 TF091C AHE1 3392519
Also Fan wich broke while trying to remove clockwise as instructed to on back. Can i get the parts through whitegoods. Might as well tell you the fault it would not start Found resistor O/C Loads of fluff so removed Motor Checked contacts on switch on Motor found to be burnt cleaned de- fluffed built back up again.Thanks Rob
July 7, 2006 at 9:33 pm #181222johnmac11
ParticipantRe: Whirlpool USA T/D Parts Required
The fan wheel 481951548051 and the resistor is 481912118255.
I have never changed the resistor on this model and have probably came across hundreds over the years, before ordering I would check the continuity of the stat next to the fan. Every time I have a dead one this is the problem.
If you send an email to spares@ukwhitegoods.co.uk Dave will sort out the parts for you.
John
July 7, 2006 at 9:49 pm #1812237390ROBERTS
Hi John I had never been to one of these before it was a real mess of fluff That is reason cleaned motor etc also a little bit nosey i am like that. What made me think it was the resistor i cant get any reading on it at all. should it be C/C or am i barking up the wrong tree. Should 4 terminals be C/C on stat. Horizontal terminals were O/C is that where the fault lies. Appreciate your help Thanks
RobJuly 7, 2006 at 10:39 pm #181224johnmac11
on the back of this dryer there are two stats and a thermal fuse, the thermal fuse is probably the one you want, it is the nearest component to the blower wheel and has a red wire on one side and a tan wire on the other. This fuse should be c/c. part no: 481925228095
The stat with four wires is the operating stat, the two violet wires should have a reading between 22.4k-33.6k the red and white/ red should be closed circuit. If the operating stat was faulty the dryer would still turn, very rarely goes faulty.
John
July 7, 2006 at 10:55 pm #1812257390ROBERTS
Thanks John you are a gentleman I will go back tomoro and check the stat tomoro before i order parts.
thanks again John
Rob -
