switch on door locks timer ticks once then does nothin on any programme even drain spin suspect module 😳 but dont do meny whirpool stuff any clues guys?
I would be more inclined to check all the connectors to the module/pcb before i changed a board.. done a couple of w/pools with odd faults like you describe only to find it was a bad connection to the board!
tighten em up then test.
