whirlpool washer
  • #65664
    keith hore
    The drum of my machine wont turn at all.It will fill and drain but wont turn.I removed the motor and checked my resistance readings and they all seem fine and the brushes are good.Has any 1 got any ideas.
    #361453
    stepeheno
    Re: whirlpool washer
    Check all the wiring from the motor to the timer / pcb’s for continuity.
    Examine the timer / pcb’s for any obvious damage – blown components, scorching, dry joints, carbon deposits etc.
    When testing the motor did you test the TOC and the tacho?
