Whirlpool washer dryer
  • #87499
    cornflakes
    Model AWZ612
    Called recently to a no heat on drying cycle
    Found resettable TOC open circuit
    Reset. Unit producing heat
    Removed heat chamber cover to check for blockage..clean
    Checked air inlet to drum. Again clear
    Air fan running
    Ran dryer cycle all ok.
    Client rang today again no heat on dryer
    Asked her about load size..says just a normal basket full?
    Any ideas where to check out next
    Thermostats etc
    Or has resettable TOC failed
    Many thanks
    Graham
    #435056
    Re: Whirlpool washer dryer
    Smeg model that one. Usual reasons are blocked fan blade (fluff in the gaps between the blades), no water inlet on dry, front drier ntc (in bellows between heater and door seal) covered in fluff upsetting its readings. Have also had fan motors intermittent start up- just sit there humming instead of spinning and next 10 times will work fine or as you suggested, faulty resettable toc or connectors producing its own heat.
