Whirlpool washer dryer AGW338 Problems
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Whirlpool washer dryer AGW338 Problems
  • #14983
    Krissy
    My brother has this machine and says if washing a light load it works ok, but on a heavier load there is a squealing noise from the top of the drum and it will not turn…
    Any ideas as to the problem..
    chris
    #161591
    Goatboy
    Re: Whirlpool washer dryer AGW338 Problems
    It sounds like an underpowered motor, which could be the carbon brushes, except for…
    Krissy wrote:…but on a heavier load there is a squealing noise from the top of the drum…
    I don’t know what that could be! 😕 Unless there’s a foreign body in the tub.
    Have you tried Repairs@ ?
    #161592
    AWG338? Merloni built washerdryer – induction motor, so drive belt slack is most likely cause of the fault. There are no brushes on this machine.
    Power off if investigating………
    Goatboy
    Penguin45 wrote:…induction motor…
    😳 I didn’t look it up, obviously! 😳
