Whirlpool washer flooding over?
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Whirlpool washer flooding over?
  • #70144
    AWOE 8758
    12nc:859297815000..S/N:410928018515
    Fill valve OK.
    Pressure switch ‘appears’ to be working, blowing down the pressure hose doesn’t appear to be blocked, not easy to tell and it has a sealed tub so not sure how easy it would be to clean pressure chamber.
    Set to wash it starts to fill and tumble right away, fill to what you would expect to be a normal level, stops filling for a couple of seconds then starts to fill again, keeps on repeating this, 20 or 30 seconds of fill, stop for a couple of seconds then filling again. Had to cancel once the water was halfway up the door.
    First one of these I have seen, does the front panel come of as easily as the older Whirlpool machines?
    Anyone encountered this problem, it would point to a control fault but not 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} sure. 😕
    suedehead1
    Re: Whirlpool washer flooding over?
    hole in pressure switch tube perhaps,
    i believe you have to take the bezel off before the
    front comes off.
    #377189
    Hmmm, it doesn’t behave like one with a hole in hose. The intervals of fill and then no fill seem to be constant, as if being switched at set times. Due to call back later this week so will check it out all the same.
