whirlpool washer totally dead (just 18mths old)
Home Forums Public Support Forums Help And Support Washing Machine Help Forum whirlpool washer totally dead (just 18mths old)
  • #44178
    justinbarrow
    We have a whirlpool washer model number: AWO/R 4205 and the mrs got a bra bone stuck which went into the outer drum, We also had a rip in the door seal so wanted to find this bra bone which i managed to recover.
    Now the problem is that when i now plug the machine in there are no led`s whatsoever and its totally dead, I have checked the fuse and this is fine also the socket is ok and there is continuity in the power flex and voltage where the flex goes into the washer.
    There is also voltage present at the wiring that goes to the control board at the front.
    I dont know what else i could check as i cant get over that trying to remove a bra bone (none electrical repair) would result in there being no response whatsoever.
    is there a main power supply unit i could check that feeds the machine, Any help would be great as I hope its not the main board.
    #280062
    justinbarrow
    Re: whirlpool washer totally dead (just 18mths old)
    Forgot to mention I recovered the bra bone from disconecting the pipe under the outer drum at the bottom which lead to the drain pump I also found coins, paperclips and hairclips.
    Its amazing what was in there :rolls: Thought down the side of the sofa would of been worse.
