Re: Whirlpool washer will not spin
shiner3lima wrote:The only thing i havent checked is the filter that is fitted inside the waste outlet pipe. Could this be the problem?
There is no filter in the waste hose, the filter is part of the drain pump you have already replaced behind the circular flap lower right on the machine 😉
FP is a drain error so it’s likely there is a blockage somewhere as the pump has been replaced.
Power off when checking :zap:
