whirlpool washerdryer awz410 constantly filling
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries whirlpool washerdryer awz410 constantly filling
  • #74542
    RHrepairs
    I have a awz410 here, and when i select a programme, it constantly fills whilst continuing the program as you can hear the element beginning to heat the water. Its not a faulty valve and i have changed the timer and it still continues to do the same. Funny thing though is if i turn off the power at the mains while its its filling, and turn it back on it stops filling and continues the program as normal. Any ideas? Would it be the pressure switch or would the wiring be wrong on the pressure switch?
    #391965
    Re: whirlpool washerdryer awz410 constantly filling
    Richardhayes55 wrote: Its not a faulty valve
    Have you replaced it then?
    #391966
    RHrepairs
    Replaced the valves and pressure switch and still the same outcome. Going to try the module in the morning.
