Replacing the despenser unit due to leak…I am 3 screws away from removing it but they are each in a locating hole. Ive managed to find a socket set small enough to get into the hole (approx 8mm diameter) but the 5mm was too small and 6mm was too big, same with imperial sizes. Is there a special tool for this? Help!
Many thanks
Model No: 859247415700
Serial No: 410703002133
Replacement Part No: 5045173504196
