Whirlpool Washing Machine error F06
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Whirlpool Washing Machine error F06
  • #76638
    Jazzynash
    Can anyone one help I have Whirpool 6th Sense model AWOE 9558B washing machine with error code F06 pointing to control board before I change this is there anything I need to look at?
    I have checked carbon brushes these have abit of life approx 25mm, machine seems to work upto point of rinse/spin then throws error code F06
    #399331
    Jazzynash
    Re: Whirlpool Washing Machine error F06
    I notice that 48 views have taken place but not 1 answer surely there must be an engineer out there who can help please please 😥
    #399332
    Andy jones
    Does it actually go into rinse, if so is it pumping correctly
    #399333
    Jazzynash
    Hi Andy
    Many thanks for your reply
    Yes pump is ok as I removed & checked this when I have on spin only it does drain water away I did rotate the drum by hand from rear of machine,workrd for about 2mins then stopped as if it wasn’t able to pick up speed?
    #399334
    I don’t have the info on that model, Whirlpool are a bit mean on info but, for those that I do have all list E06 as being a motor tacho issue.
    Could be loose, could be wring to it, could be faulty, could be the motor itself or could be the PCB.
