Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Whirlpool washing Machine Mod AWO3761/S
- This topic has 9 replies, 5 voices, and was last updated 18 years, 2 months ago by
Ashby.
February 10, 2008 at 8:53 am #34471
Ashby
ParticipantHi, intermittent fault with this machine.
after the program is set. the machine will start, drain then either carry on or will stop and the red door locked light will flash. after a few mins it will perhaps start again for a few secs then do the same again. No fault code is coming up on the display either. Anyone familiar with these machines?
Thanks for your help.
AshbyFebruary 11, 2008 at 3:56 pm #242807SparkyP
ParticipantRe: Whirlpool washing Machine Mod AWO3761/S
Hi Ashby
Sounds like the brushes on the motor. When you select a cycle it locks the door then pumps then waits for the motor to turn if it doesn’t turn the door lock light flashes. Quite a common error.
Hopes this points you in the right directionSparkyp
February 11, 2008 at 9:10 pm #242808Ashby
Hi Sparkyp,
Thanks for your help. will have a look at the brushes.
AshbyFebruary 12, 2008 at 7:58 pm #242809Ashby
Hi SparkyP,
Changed the brushes on this motor today and it spun fine.
30 mins later the customer phoned to say they had put a load in and the same thing happened again.
the door light started flashing again.
Any ideas?
Many Thanks.
Ashby 😳February 13, 2008 at 8:28 am #242810SparkyP
Hi Ashby
Sounds like the loom from motor to timer then (M7 lead it is called) ….when its under load.. i have had a few do this. Wot were the brushes like were they worn down? If they looked ok and a good length then its the loom.
Sparkyp
February 13, 2008 at 8:49 am #242811Ashby
Hi SparkyP,
Yes, the brushes were well worn down. I will check the loom.
Many thanks for your help.
Much Appreciated.
AshbyFebruary 2, 2009 at 6:02 pm #242812neilsukwg
Got same fault as described here,
Changed brushes as advised, machine worked ok for a fortnight, now back to flashing door light.
Have had brushes back off to check, all ok.
Did you find a fault in the loom? Have you cured fault?
Neil
February 2, 2009 at 6:38 pm #242813Micky 32
Sure it’s not a faulty door lock? I’m nearly sure i called to one with the same problem but the fault wasn’t intermittent the light kept flashing. Replaced lock and all was fine.
February 2, 2009 at 11:54 pm #242814neilsukwg
Eliminated interlock by running machine on 2′ drain cycle. It will do that no problem.
Door lock light comes on within 30 secs on any other programme.
February 5, 2009 at 12:25 pm #242815bazza500
neilsukwg wrote:Eliminated interlock by running machine on 2′ drain cycle. It will do that no problem.
It will do the drain cycle with the door open.
