Side by side F/F S20D RSB33-A/G 11 0447 026461
This ff is not dispensing water. Checked valve ok. I have traced the blockage to the length of tubing in the door. When i disconected the tube at the bottom the water pumps out when i press the dispenser lever. I managed to push a piece of wire about a foot up the tube at the dispenser end and about 2 feet up the tube from the bottom end of the door but its still blocked. How do you replace the tube in the door? I removed the front control board and undid the 4 screws on the casing of the dispenser but could not remove it. It was still stuck solid but i could not work out what was holding it.
Subs, is it possible that the blockage is ice? The water is probably frozen in the tube, so replacing it won’t help. Insulation in door is likely broken down and requires new door. 🙁
