Went to this machine a couple of months ago after it had leaked, the leak was caused by the rear drum seal that had shredded and bits of rubber were scattered on the floor underneath. drum seal and heater replaced and machine tested OK.
Got a call back today to find that the seal had shredded again and the drum back plate had rotated about 45deg clockwise and had pulled the dryer hose out of the back of drum, luckily all the wiring is still intact. The customer stated that the machine was vibrating a lot when it went into spin.
I suspect that the module may be causing the machine to jump into spin and just wondering if anyone else has had similar problems with this type of machine, same as the servis WD
Colin
