Re: whirlpool wdp 2440 problem
4 flashes on a Whirlpool is a drainage problem, is it brand new? check the installation, maybe a bung in the sink trap, or drainhose pushed into the standpipe to far?
has there been a broken glass in there?, take the filters out and feel inside the sump to see if anyting is there. If not, power off, remove the plinths make sure you have towells handy, because you will get wet! the pump is just a twist lock, push the clip down and twist the pump anti clockwise and you have access the the impellor.
(presuming the model is a full size dishwasher)
