Whirlpool WFE 2B19 UK beeping and blinking lights
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Whirlpool WFE 2B19 UK beeping and blinking lights
  • #97085
    cmulhol57
    About half an hour into the Normal cycle the display light moves Eco and the machine starts beeping and blinking lights constantly. The cycle does not continue. All other cycles are running fine. Any help would be greatly appreciated.
    #466057
    the fault codes on this machine are designated by 4 lights
    the 3 programme position lights ( wash, dry and end) plus the start pause button
    we would need to know if those lights are on on or off at the time of the fault
    a quick pic would make it easier
    cmulhol57
    Hi Dave,
    Thanks for your reply. I’m having trouble trying to upload a picture. The indicator light at the On-Off/Reset button and indicator light at the Start/Pause button are blinking constantly. The indicator light at the for Eco is staying on constantly.
    Colm
    #466059
    host the photo on another website and post a public link to it
    cmulhol57
    well am completely lost now
    the only fault list seems to bear no resemblance to your machine
    if I had to make a guess I would say flood protection but it would affect all programmes
    you can check where the motor is for signs of leak
    is it heating ok ?
    #466062
    cmulhol57
    The fault only seems to occur in cycles above 50 degrees
    #466063
    so it is heating ?
    and is it plumbed into cold or hot water
    cmulhol57
    Cold water
    #466065
    ok so does it heat ?
    i am trying to figure out what its trying to do when the fault occurs
    Dieselyahoo
    Dear Friend! I sorted out this problem. The solve is the plastic blue sensor under the motor pipes and everything, the most lower parts with 2 orange wire. If you disconnect and try to start you get this fault 1led from the start.
